Module ClickToDial En
Asterisk | |
Numero/ID of module | 58 |
Developer doc. of module | Module ClickTodial (developer) |
This module allows you to trigger a phone call with a simple mouse click on a phone number in Dolibarr. Any SIP server with an URL interface for the ClickToCall can be used. There is also information for setup with Asterisk.
With Asterisk
This is how to fill the specific setup for Asterisk:
- Add Url
- Go on page Setup - Other and add constants
ASTERISK_HOST with IP of your asterisk server (ie: 127.0.0.1) ASTERISK_TYPE with managed protocol (ie: SIP/) ASTERISK_INDICATIF with prefix to add in phone number (ie: 0 or NONE) ASTERISK_PORT with port of Asterisk sever (ie: 5038)
- Create a new console user on your Asterisk server ( File /etc/asterisk/manager.conf )
[dolibarruser]
secret = dolibarrpass
deny=0.0.0.0/0.0.0.0
- Enter Asterisk informations on your Dolibarr user card, tab ClickToDial
ClickToDial Login : dolibarruser ClickToDial Password : dolibarrpass ClickToDial Id caller (phone) : your phone
Once setup is finished, all phone number in Dolibarr screens are now links you can click. If you do so, Dolibarr will call then page to send informations to Asterisk server to execute the phone call. The Asteriks server should do the rest.
