Module Membership management
Foundations
Numero/ID of module 310
  • Reporting.
Creation of a member type
Creation of personalized attributes
Diagramme d'états d'un adhérent
New or renew a subscription
Revoke a member
Example of use case
UCFO01: The foundation wants to define a new type of members
Situation The foundation wants to define a new type of members
Actions I create a new type from Menu foundation - Setup - Members types - New type.
UCFO02: A new member come with a cheque or cash
Situation A new member come with a cheque or cash
Actions I create the new member from Menu foundation - New member.
If you want this member to have a Dolibarr access, click on "Create a user" from its member card view. If you want this member to be a third party to send him proposals, invoices, etc, click on "Create a third party" from its member card view. I create a new subscription from tab subscription of member card.
UCFO03: A member come to renew its subscription with a cheque or cash
Situation A member come to renew its subscription with a cheque or cash
Actions I go on the member card then tab Subscriptions.
I add the new subscription.
UCFO04: I want to revoke a member
Situation I want to revoke a member
Actions I go on the member card.
I click on Revoke.
