Module PHPSysinfo
Revision as of 12:23, 8 October 2011 by Eldy (talk | contribs)
Module name
Dolibarr min version: 2.9.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2011-10-8
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
From the application
Manually
unzip modulefile.zip
Click on menu entry "PHPSysinfo". System information will be shown on main page.
