Module Pibarcode
Revision as of 18:18, 24 September 2011 by Eldy (talk | contribs) (→‎Development)
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2011-09-24
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
From the application
Manually
unzip modulefile.zip
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
