Module NumberWords
Revision as of 18:15, 24 September 2011 by Eldy (talk | contribs)
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2011-09-24
With this module, Dolibarr is able to translate decimal number or amount into full text strings ("110 dollars" will give "one hundred and ten dollars")
From the application
Manually
unzip modulefile.zip
Then see "Usage"
  • If you are an end user: add the string __TOTAL_TTC_WORDS__, __TOTAL_HT_WORDS__, __TOTAL_VAT_WORDS__ in any "free text for PDF" area in setup of invoices, orders, proposals... This string will be replaced with the amount with tax, without tax or for vat in full clear alphabetic text.
  • If you are a developer: You can also use, anywhere in the code, the method
$langs->getLabelFromNumber($mynumber,0|1)
to get full text string of a number (if second parameter is 0) or an amount (if second parameter is 1).
