Table llx c availability
Revision as of 15:42, 17 August 2011 by Simnandez (talk | contribs) (Created page with "Category:Table SQL {{ListOfTables}} = Content/Contenu/Contenido = {{flag en}} Contains the list of possible availability types, depending on your Dolibarr configuration. Us...")
  Contains the list of possible availability types, depending on your Dolibarr configuration. Used to generate drop-down lists, and to filter down lists of results.
  Contient la liste des types de disponibilité disponibles selon votre configuration du système. Utilisée pour générer des listes déroulantes et pour filtrer des listes de résultats.
  contiene la lista de los tipos de disponibilidad disponibles dependiendo de la configuración de su Dolibarr. Usada para generar las listas desplegables y filtrar los listados resultantes.
Structure
Table
rowid int(11) NO PRI id of availability
code varchar(30) NO UNI code of availability
label varchar(60) NO label of availability
active tinyint(4) NO 1 is the availability active?
Keys
Key Type Fields
PRIMARY PRIMARY id
uk_c_availability UNIQUE code
