Dolibarr for OpenSuse (rpm package)
Revision as of 12:12, 9 August 2011 by Eldy (talk | contribs) (moved Dolibarr for OpenSuse to Dolibarr for OpenSuse (rpm package))
Dolibarr for OpenSuse is a version of Dolibarr ERP/CRM, packaged with Mysql, PHP and Apache with an automatic installer for OpenSuse users that don't have any technical knowledge.
In a few seconds, after installing this package, you are able to work on Dolibarr, even if you don't have already a web server or if you don't know what is Apache, Mysql or PHP. Everything is installed for you.
It's an "all in one" package that can be downloaded from page http://www.dolibarr.org/downloads/. You will find it into the category "stable versions".
For install, you can click on the dolibarr.x.y.z.rpm file if you use the file manager, or inside a terminal console type:
$ yast --install dolibarr.x.y.z.rpm
where x.y.z is the dolibarr version, ex. dolibarr.2.8.0.rpm
