Module Commercial Proposals - Quotes
Numéro/ID du module 20
Doc développeur du module Module Commercial Proposals (developer)
A proposal is a document you suggest to a customer to give him an idea of what you can do/sell at which price.
Life cycle / Business rules
  待完成,欲帮助完成,注册帐号,点击“编辑"
A Complete Proposal
The creation of a business proposal is from the customer or prospect in the Commercial. To create a proposal you must have a defined contact for this client and the module must be enabled!).
Follow the signs to create a draft proposal, then validate it when it is ready (as opposed to bills you can modify a proposal accepted).
Closure of a proposal
Signed as close a proposal when the customer has agreed. At the close of a business proposal, identity attached is automatically set as a customer if it was previously classified as a prospect. Also if you setup correctly Module Workflow, an Order "draft" can be automatically created.
Module
Dolibarr can handle several models of proposals, which must be active in the Configuration module. You can create your templates yourself you just have to know the language php. The models proposed are located in / includes / modules / Proposals /
Example of use case
UCCP01:
Situation
Actions
