Module Workflow
Revision as of 08:56, 1 August 2011 by Eldy (talk | contribs) (moved Module Workflow EN to Module Workflow En)
Workflow | |
Numero/ID of module | 6000 |
User doc. of module | Cette page |
Developer doc. of module | Module Workflow (development) |
This module allows you to install some workflow links to have automatic object creation. for example, when closing a commercial proposal with status "signed", this module will can automatically an order.
Life cycle / Business rules
This module show only available workflows according to activated modules.
