Module Workflow
Revision as of 08:43, 1 August 2011 by Eldy (talk | contribs) (Created page with "Category:Workflow {{TemplateDocUser}} {{TemplateModEN}} {{BasculeDevUser| nom=Workflow| num=6000| devdoc=Module Workflow (development)| userdoc=Cette page|}} = Introduct...")
Workflow | |
Numéro/ID du module | 6000 |
Doc développeur du module | Module Workflow (development) |
This module allows you to install some workflow links to have automatic object creation. for example, when closing a commercial proposal with status "signed", this module will can automatically an order.
Life cycle / Business rules
This module show only available workflows according to activated modules.
