Module Commercial Proposals - Quotes
| Commercial Proposals | |
| Numéro/ID du module | 20 |
| Doc développeur du module | Module Commercial Proposals (developer) |
A proposal is a document you suggest to a customer to give him an idea of what you can do/sell at which price.
Life cycle / Business rules
A Complete Proposal
The creation of a business proposal is from the customer or prospect in the Commercial. To create a proposal you must have a defined contact for this client and the module must be enabled!).
Follow the signs to create a draft proposal, then validate it when it is ready (as opposed to bills you can modify a proposal accepted).
Closure of a proposal
Signed as close a proposal when the customer has agreed. At the close of a business proposal identity attached is automatically set as a customer if it was previously classified as a prospect, an Order "draft" is automatically created.
Module
Dolibarr sait gérer plusieurs modèles de propositions, qui doivent être actifs dans la partie Configuration du module. Vous pouvez créer vous même vos modèles il vous suffit pour cela de connaitre tout de même le language php. Les modèles de propositions se trouvent dans /includes/modules/propale/
Example of use case
| UCCP01: | |
| Situation | |
| Actions | |
