Module MultiCompany
| Module name | |
| Editor / Editeur | Regis Houssin - http://www.dolistore.com/ |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2011-07-22 |
| Note / Nota |
With this module, Dolibarr is able to manage several instances with only one installation (one unzipping and one database)
From the application
Manually
unzip modulefile.zip
See doliforge.com
