Table llx usergroup rights
Revision as of 16:03, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the link between a group and its permissions (Table llx_usergroup and Table llx_rights_def)
  Contient l'association entre un groupe et ses droits (Table llx_usergroup et Table llx_rights_def)
  Contiene los enlaces entre un grupo y sus permisos (Table llx_usergroup y Table llx_rights_def)
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_usergroup int(11) NO UNI ID of user (llx_usergroup->rowid)
fk_id int(11) NO UNI ID of right (llx_rights_def->id)
Keys
Key Type Fields
PRIMARY PRIMARY rowid
fk_usergroup UNIQUE fk_usergroup,fk_id
