Table llx product lang
Revision as of 15:41, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the languages related to a product
  Contient les languages rattachés à un produit
  Contiene los idiomas relacionados con un producto
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_product int(11) NO UNI 0 ID of product (llx_product->rowid)
lang varchar(5) NO UNI 0 lang of product
label varchar(255) NO label of product in this language
description text YES NULL description
note text YES NULL notes
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_product_lang UNIQUE fk_product,lang
