Table llx prelevement lignes
Revision as of 15:38, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the lines of standing orders. This table is linked to Table llx_prelevement_bons
  Contient les lignes des prelevement bons. Cette table est liée avec la Table llx_prelevement_bons
  Contiene las líneas de las domiciliaciones. Esta tabla está vinculada con la Table llx_prelevement_bons
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_prelevement_bons int(11) YES MUL NULL ID of standig order (llx_prelevement_bons->rowid)
fk_soc int(11) NO ID society (llx_societe->rowid)
statut smallint(6) YES 0 status
client_nom varchar(255) YES NULL client name
amount real YES 0 amount
code_banque varchar(7) YES NULL bank code
code_guichet varchar(6) YES NULL bank office code
number varchar(255) YES NULL bank account number
cle_rib varchar(5) YES NULL RIB key
note text YES NULL comentary
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_prelevement_lignes_fk_prelevement_bons MULTIPLE fk_prelevement_bons
