Table llx paiementfourn facturefourn
Revision as of 15:36, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Establishes the link between payments isued and the corresponding supplier invoices.
  Etablit le lien entre les paiements émis et les factures fournisseur correspondantes.
  Establece el enlace entre los pagos emitidos y las facturas de proveedor correspondientes.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_paimentfourn int(11) YES UNI NULL (llx_paiementfourn->rowid)
fk_facturefourn int(11) YES UNI NULL (llx_facture_fourn->rowid)
amount double YES 0 amount of payment
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_paiementfourn_facturefourn UNIQUE fk_paiementfourn,fk_facturefourn
idx_paiementfourn_facturefourn_fk_facturefourn MULTIPLE fk_facturefourn
idx_paiementfourn_facturefourn_fk_paiementfourn MULTIPLE fk_paiementfourn
