Table llx import model
Revision as of 15:26, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains import models
  Contient des modèles d'importation
  Contiene los modelos de importación
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_user int(11) NO 0 ID of user made the model (llx_user->rowid)
label varchar(50) NO UNI label of model
type varchar(20) NO UNI type of import
field text NO List of fields to import when using this import model
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_import_model UNIQUE label,type
