Table llx fichinterdet
Revision as of 15:25, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains the details interventions of the interventions module. This table is linked to Table llx_fichinter
Fr verysmall.png Contient les détails des interventions du module interventions. Cette table est liée avec la Table llx_fichinter
Es verysmall.png Contiene los detalles de las intervenciones del módulo intervenciones. Esta tabla está vinculada con Table llx_fichinter
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_fichinter int(11) YES NULL ID of intervention (llx_finchinter->rowid)
date datetime YES NULL date of intervention line
description text YES NULL description of intervention line
duree double YES NULL intervention duration
rang int(11) YES 0 view order
Keys
Key Type Fields
PRIMARY PRIMARY rowid
