Table llx facturedet rec
Revision as of 15:24, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the lines of predefined invoices, this table is linked with Table llx_facture_rec.
  Contient les lignes des factures prédéfinies, cette table est liée avec la Table llx_facture_rec.
  Contiene las líneas de las facturas predefinidas, esta tabla está vinculada con Table llx_facture_rec.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_facture int(11) NO ID of related facture (llx_facture_rec->rowid)
fk_product int(11) YES NULL ID of related product (llx_product->rowid)
product_type int(11) YES 0 type of product
description text YES NULL description of product
datec datetime YES NULL creation date
tva_taux real YES 19.6 VAT tax
qty real YES NULL quantity
remise real YES 0 discount
remise_percent real YES 0 percent discount
price real YES NULL final price
subprice real YES NULL price before discount
total_ttc real YES NULL total with tax
total_ht ral YES NULL total excluding tax
total_tva real YES NULL total tax
Keys
Key Type Fields
PRIMARY PRIMARY rowid
