Table llx export model
Revision as of 15:19, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains export models
Fr verysmall.png Contient des modèles d'exportation
Es verysmall.png Contiene los modelos de exportación
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_user int(11) NO 0 ID of user made the model (llx_user->rowid)
label varchar(50) NO UNI label of model
type varchar(20) NO UNI type of export
field text NO List of fields to export when using this export model
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_export_model UNIQUE label,type
