Table llx expeditiondet
Revision as of 15:18, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the details of shipments. This table is linked to Table llx_expedition
  Contient les detail des expeditions. Cette table est liée avec la Table llx_expedition
  Contiene los detalles de las expediciones. Esta tabla está vinculado con Table llx_expedition
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_expedition int(11) NO MUL ID of expedition (llx_expedition->rowid)
fk_origin_line int(11) YES NULL Correspondence of the line with the original document (propal, order)
fk_entrepot int(11) YES NULL ID of warehouse depart product (llx_entrepot->rowid)
qty real YES NULL quantity of shipped product
rang int(11) YES 0 order view
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_expeditiondet_fk_expedition MULTIPLE fk_expedition
