Table llx ecm directories
Revision as of 14:49, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains the list of directories of Electronic Content Management. The documents are in the Table llx_ecm_documents
Fr verysmall.png Contient la liste des répertoires de la Gestion Electronique de Documents. Les documents sont dans la Table llx_ecm_documents
Es verysmall.png Contiene la lista de los directorios de la Gestión Electrónica de Documentos. Los documentos se encuentran en Table llx_ecm_documents
Structure
Table
rowid int(11) NO PRI auto_increment technical index
label varchar(32) NO label of directory
entity int(11) NO 1 multi company id
fk_parent int(11) YES NULL parent
description varchar(255) NO description of directory
cachenbofdoc int(11) NO 0
date_c datetime YES creation date
date_m timestamp NO CURRENT_TIMESTAMP last update date
fk_user_c int(11) YES NULL ID of creator user (llx_user->rowid)
fk_user_m int(11) YES NULL ID of last modifier user (llx_user->rowid)
Keys
Key Type Fields
PRIMARY PRIMARY rowid
