Table llx document
Revision as of 14:45, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
  Contains the information of documents built by module paper mailing
  Contient les informations des documents générés par le module publipostage
  contiene la información de documentos
Structure
Table
rowid int(11) NO PRI NULL auto_increment technical index
name varchar(255) NO name of document
file_name varchar(255) NO file name of document
file_extension varchar(5) NO file extension of document
date_generation datetime YES NULL date of document generation
fk_owner int(11) YES NULL ID owner of document (llx_user->rowid)
fk_group int(11) YES NULL ID of group (llx_usergroup->rowid)
permissions char(9) YES rw-rw-rw access permissions
Keys
Key Type Fields
PRIMARY PRIMARY rowid
