Table llx deplacement
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the expenses and trips notes
Contient les notes de frais et déplacements
Contiene las notas de gastos y desplazamientos
Structure
Table
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| ref | varchar(30) | NULL | reference donation (TODO change to NOT NULL) | |||
| entity | int(11) | NO | 1 | multi company id | ||
| date_c | datetime | NO | date of creation | |||
| tms | timestamp | NO | CURRENT_TIMESTAMP | last update date | ||
| dated | datetime | YES | NULL | date of trip | ||
| fk_user | int(11) | NO | ID of user made the trip note (llx_user->rowid) | |||
| fk_user_author | int(11) | YES | NULL | ID of creator user of trip note (llx_user->rowid) | ||
| type | varchar(12) | NO | type of trip note | |||
| fk_statut | integer | YES | 1 | Status of trips/expenses (0=Draft, 1=Validated) | ||
| km | real | YES | NULL | amount or km | ||
| fk_soc | int(11) | YES | NULL | ID society affected (llx_societe->rowid) | ||
| fk_projet | int(11) | YES | NULL | ID proyect affected (llx_projet->rowid) | ||
| note | text | YES | NULL | notes | ||
| note_public | text | YES | NULL | public notes |
Keys
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
