Table llx compta
Revision as of 14:34, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains
Fr verysmall.png Contient
Es verysmall.png Contiene
Structure
Table
rowid int(11) NO PRI auto_increment technical index
datec datetime YES NULL date of creation
datev date YES NULL date of value
amount real NO 0 amount
label varchar(255) YES NULL label
fk_user_author int(11) YES NULL ID of author user (llx_user->rowid)
fk_user_valid int(11) YES NULL ID of validator user (llx_user->rowid)
valid tinyint(4) YES 0 is validated?
note text YES NULL notes
Keys
Key Type Fields
PRIMARY PRIMARY rowid
