Table llx commande fournisseurdet
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains details of providers orders. This table is linked to Table llx_commande_fournisseur
Contient les détails des commandes fournisseurs, cette table est liée avec la Table llx_commande_fournisseur
Contiene los detalles de los pedidos a proveedores, esta tabla esta vinculada con Table llx_commande_fournisseur
Structure
Tables
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| fk_commande | int(11) | NO | ID of order (llx commande->rowid) | |||
| fk_product | int(11) | YES | NULL | ID of product (llx_product->rowid) | ||
| ref | varchar(50) | YES | NULL | supplier ref. of product | ||
| label | varchar(255) | YES | NULL | label of product | ||
| description | text | YES | NULL | product description | ||
| tva_tx | double(6,3) | YES | 0.000 | VAT taxes | ||
| qty | real | YES | NULL | Quantity of product | ||
| remise_percent | real | YES | 0 | discount percentage | ||
| remise | real | YES | 0 | discount amount | ||
| subprice | double(24,8) | YES | 0.00000000 | unit price before | ||
| total_ht | double(24,8) | YES | 0.00000000 | total excluding tax | ||
| total_tva | double(24,8) | YES | 0.00000000 | total tax | ||
| total_ttc | double(24,8) | YES | 0.00000000 | total with tax | ||
| product_type | int(11) | YES | 0 | type of product | ||
| date_start | datetime | YES | NULL | start date if service | ||
| date_end | datetime | YES | NULL | end date if service | ||
| info_bits | int(11) | YES | 0 | TVA NPR or not |
Keys
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
