Table llx commande fournisseur dispatch
Revision as of 14:32, 19 July 2011 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains the provider orders dispatch.
Fr verysmall.png Contient les envois des commandes fournisseurs.
Es verysmall.png Contiene los envíos de los pedidos a proveedores.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_commande int(11) YES MUL NULL ID of order (llx_commande_fournisseur->rowid)
fk_product int(11) YES NULL ID of product (llx_projet->rowid)
qty float YES NULL Quantity
fk_entrepot int(11) YES NULL ID of warehouse (llx_entrepot->rowid)
fk_user int(11) YES NULL ID of user (llx_user->rowid)
datec datetime YES NULL date of dispatch
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_commande_fournisseur_dispatch_fk_commande MULTIPLE fk_commande
