Subscription amount Dolibarr Foundation
Revision as of 11:58, 19 July 2011 by Eldy (talk | contribs)
Back to Dolibarr
foundation home page
You will find here minimum amount for subscriptions to the Dolibarr foundation, depending on your status.
Physical persons
This is when you subscribe for yourself.
Minimum amount of subscription for physical persons is: 20 € minimum.
Moral persons
If your subscription is for your company, foundation, university, the amount depends on characteristics of this company, foundation or university.
Companies
Subscription amount depends on company's turnover :
  • Turnover lower than 100 000 € : subscription is 50 €
  • Turnover from 100 000 to 200 000 € : subscription is 100 €
  • Turnover from 200 000 to 500 000 € : subscription is 200 €
  • Turnover from 500 000 to 1.5 millions € : subscription is 400 €
  • Turnover from 1.5 to 3 millions € : subscription is 750 €
  • Turnover from 3 to 5 millions € : subscription is 1 500 €
  • Turnover higher than 5 millions € : subscription is 2 000 €
Foundations
For foundations, subscription depends on your budget :
  • Budget lower than 100 000 € : subscription is 50 €
  • Budget from 100 000 € to 200 000 € : subscription is 100 €
  • Budget from 200 000 € to 500 000 € : subscription is 200 €
  • Budget from 500 000 € to 1.5 millions € : subscription is 400 €
  • Budget from 1.5 to 3 millions € : subscription is 750 €
  • Budget from 3 to 5 millions € : subscription is 1 500 €
  • Budget higher than 5 millions € : subscription is 2 000 €
Other
For towns, universtities and any other institutions, subscription is 100€.
