Table llx c stcomm
Revision as of 10:24, 19 July 2011 by Eldy (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png This table contains the commercial contact status of each third party of type Prospect. i.e. "do not contact", "contact pending", "to contact asap",...
Fr verysmall.png Contient les statuts de contact de chaque tiers de type Prospet . Par exemple "ne pas contacter", "contact en cours", "à contacter au plus tôt", ...
Es verysmall.png Contiene los estados de contacto de cada tercero de tipo Cliente potencial. Por ejemplo "no contactar", "contacto en curso", "a contactar",...
Structure
Table
id int(11) NO PRI technical index
code varchar(12) NO UNI code of status
libelle varchar(30) YES NULL label of status
active tinyint(4) NO 1 is the status active?
Keys
Key Type Fields
PRIMARY PRIMARY id
code UNIQUE code
