Table llx c prospectlevel
Revision as of 10:21, 19 July 2011 by Eldy (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains different possible prospect level of prospects.
Fr verysmall.png Contient les différents prospect levels possibles des prospects.
Es verysmall.png Contiene los diferentes niveles posibles de clientes potenciales.
Structure
Table
code varchar(12) NO PRI technical index
label varchar(30) YES NULL label of prospect level
sortorder smallint(6) YES NULL view order of prospect level
active smallint(6) NO 1 is the prospect level active?
Keys
Key Type Fields
PRIMARY PRIMARY code
