Table llx c paper format
Revision as of 10:18, 19 July 2011 by Eldy (talk | contribs) (→‎Content/Contenu/Contenido)
En verysmall.png Contains the list of available papers format to print. This table is not used for the moment.
Fr verysmall.png Contient la liste des formats de papier disponibles pour l'impression. Cette table n'est pour l'instant pas utilisée.
Es verysmall.png contiene la lista de los formatos disponibles de papel para imprimir.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
code varchar(16) NO code of format
label varchar(50) NO label of format
width float(6,2) YES 0.00 width of papier
height float(6,2) YES 0.00 height of papier
unit varchar(5) NO unit of measure
active tinyint(4) NO 1 is the papier format active?
Keys
Key Type Fields
PRIMARY PRIMARY rowid
