Table llx c effectif
Revision as of 10:04, 19 July 2011 by Eldy (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains ranges of number of employees in a company. Used to generate drop-down lists
Fr verysmall.png Contient les différentes tranches de nombres d'employés dans une entreprise. Utilisée pour générer des listes déroulantes.
Es verysmall.png Contiene los rangos de número de empleados en una empresa. Se usa para genarar las listas desplegables
Structure
Table
id int(11) NO PRI auto_increment technical index
code varchar(12) NO UNI code of range
libelle varchar(30) YES NULL label of range
active tinyint(4) NO 1 Is the range active?
Keys
Key Type Fields
PRIMARY PRIMARY id
code UNIQUE code
