Table llx c civilite
Revision as of 09:56, 19 July 2011 by Eldy (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png This table contains all the contact people's civility (Mr,Ms.,...)
Fr verysmall.png Cette table contient les civilités des contacts (M., Mme, ...)
Es verysmall.png Esta tabla contiene las cortesías de los contactos (Sr, Sra, etc.)
Structure
Table
rowid int(11) NO PRI auto_increment technical index
code varchar(6) NO code of civility
civilite varchar(50) YES NULL label of civility
active tinyint(4) NO 1 is the civility active?
Keys
Key Type Fields
PRIMARY PRIMARY rowid
code UNIQUE code
