Module Stocks En
Stock
Numéro/ID du module 52
Doc développeur du module Module Stock (developer)
Stock management module can save status for stocks of products into warehouses, edit amounts of products you have and correct them.
The setup page allows you to choose, among four options, when the stock is automatically incremented or decreased (depending on events in orders or invoices cycle of life).
Create a warehouse
The creation of a warehouse is the mandatory first step for stock management. You can create a warehouse on the Products/Services tab, clicking Stocks on the left menu and then New warehouse stock. The only required information is a reference code and a warehouse name, the other fields are optional. You must then set whether the warehouse is running or not (opened / closed). A closed warehouse cannot be used by the other Dolibarr functions. This is a good way to prepare a warehouse (by filling it up) before you turn it on, or to temporarily block during an inventory.
Allocate product stocks
Long but necessary step, it is then, for each product, to define the stock amount, in each warehouse. This has to be done from the stock tab on the page of the product, which can be found on the products section of the left menu.
Automatic stock updates
Depending on the option chosen in the module's configuration, the available stock amount is updated either at the time of the proposal, at the time of shipment, at the time of invoice, etc.. A movement of stock is then registered according to the chosen stocking criteria.
Warning: in current version (3.0.0), automatic stock updates are only applied to warehouse number 1!
Manual stock updates
If you wish to make adjustments to the existing stock amounts (because of theft, loss, aging, ...), you can do it directly via the stock tab on the page of the product.
Warehouse status
It is possible to obtain a detailed list of products and movements in a warehouse via a click on the name of the store from the list of warehouses.
Examples of use cases
UCMS01:
Situation
Actions
