Stock
Numéro/ID du module 52
Doc développeur du module Module Stock (developer)
Stock management module can save status for stocks of products into warehouses, edit amounts of products you have and correct them.
The setup page allows you to choose, among four options, when the stock is automatically incremented or decreased (depending on events in orders or invoices cycle of life).
Create a warehouse
The creation of a warehouse is the mandatory first step for stock management. You can create a warehouse on the Products/Services tab, clicking Stocks on the left menu and then New warehouse stock. The only required information is a reference code and a warehouse name, the other fields are optional. You must then set whether the warehouse is running or not (opened / closed). A closed warehouse cannot be used by the other Dolibarr functions. This is a good way to prepare a warehouse (by filling it up) before you turn it on, or to temporarily block during an inventory.
Allocate product stocks
Long but necessary step, it is then, for each product, to define the stock amount, in each warehouse. This has to be done from the stock tab on the page of the product, which can be found on the products section of the left menu.
Modification automatique du stock
Selon l'option choisie dans la configuration du module, une modification prend place au moment de la commande, au moment de la livraison, au moment de la facture, etc. Un mouvement de stock est alors enregistré selon les critères de déstockage choisis.
Modification manuelle du stock
Si l'on désire apporter des correctifs au stock existant (vol, disparition, vieillissement, ...), il est possible de le faire directement via l'onglet stock de la fiche produit.
Fiche entrepôt
Il est possible d'obtenir une liste détaillée des produits et mouvements enregistrés dans un entrepôt via un clic sur le nom de l'entrepôt dans la liste des entrepôts.
Examples of use cases
  待完成,欲帮助完成,注册帐号,点击“编辑"
UCMS01:
Situation
Actions
