Revision as of 06:54, 9 June 2011 by Simnandez (talk | contribs) (Reverted edits by Gnovaro (talk) to last revision by Eldy)
Versions
  • Dolibarr must works on:
  2. PHP 4.3 or + (Must works with no need of complementary PHP module, except module to PHP module to access database).
  3. Mysql 3.1 or +
PHP Norms
  • Dolibarr is written with PHP and supports all PHP version higher than 4.1. All files must end with extension .php
  • Usage of superglobals PHP variables must use dedicated operators $_GET, $_POST, $_COOKIES, $_SERVER, $_ENV.
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will works alos if option register_long_arrays is to off. Moreover, the code must works when PHP option register_globals is off (recommanded by PHP). It must works the same way that when option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"].
  • When several variables must be initialized with same value, you must use several lines
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
  • String must be rounded by simple quote and vairable inside string must be out of the quote.
  • Comments must use the C syntax, ie a double antislash for a comment on one line and a slash-star to open a bloc for several lines
/* Bloc of comment
 * End of bloc
for ($i = 1 , $i < 2 ; $i++)
  // comment on one line
  print $i;
  • Files must be saved with Unix format (LF) and not Windows (CR/LF). Unif format is compatible on all OS like Unix like, Windows, Mac, but the Windows text file format is no working on some PHP under Unix.
Functions must return a value strictly higher than 0 if successfull and strictly lower than 0 if error.
SQL rules
  • All SELECT * are forbidden ! Any SELECT must define complete list of fields to get. This avoid confusion. Example:
  • Into SQL requests, you must quote fields except fields that contains amounts that must be stored as double or real type. Quotes on numbers may results in saving a different value. For example 412.62 in an insert will be saved with value 412.61999512 into database fi target field has type double(24,8). Only PHP see value 412.61999512. Other tools will see 412.62 giving sensation that there is no problem. But it's PHP that hase the good vision. There is really a wrong value into database. By removing quotes on numbers, no problem occurs.
Example:
Note, problem of float numbers is same problem on all langauges and not only when inserting data into database. It occurs also with any language when you work on "real" numbers, so numbers must be, as soon as they are affected, cleaned with function price2num with second parameter defined to : 'MU', 'MT' or 'MS' depending on usage of number. (see function documentation)
Well, to be compatible with any accurency required by any country on amounts, we will use the following type into database:
- double(24,8) for any amount
- real for a quantity
  • Dolibarr must works even if Mysql option strict is active.
To activate it (recommanded when developping on Dolibarr), add the following line into the config file of your Mysql server (my.cnf)
sql-mode="STRICT_ALL_TABLES"
  • Functions NOW or SYSDATE are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is to avoid a better portability of code and a correct management of TimeZone.
HTML norms
  • All attributes of HTML tags must be in lower case and *quoted* with *"*.
For example:
  • Le javascript et l'appel aux scripts java dans les pages php est à proscrire. Si toutefois du code javascript est inclus, il doit être conditionné par le test sur "$conf->use_javascript"
if ($conf->use_javascript)
...  // Le code php qui génère du javascript est ici
  • Les popups windows ne doivent pas être utilisées, sauf pour des tooltips (et restent condtionnées par le point ci-dessus).
  • Les scripts externes sont écrits en Perl s'ils ne peuvent l'être en php, l'utilisation d'un autre langage n'est pas interdit mais doit être discuté au préalable dans la mailing list des développeurs. Le langage devra être maitrisé par au moins 2 développeurs pour en assurer la maintenance.
Squelettes de code
Afin d'uniformiser le code et d'accélérer le développement de nouveaux composants dans Dolibarr, se trouvent dans le répertoire dev/skeletons, 4 squelettes de code tout préparés.
  • 1 qui sert d'exemple de descripteur de module: myModule.class.php
  • 1 qui sert d'exemple de code pour faire une nouvelle classe: skeleton_class.class.php
  • 1 qui sert d'exemple de code pour faire une nouvelle page: skeleton_page.php
  • 1 qui sert d'exemple de code pour faire un script à exécuter en ligne de commande: skeleton_script.php
Servez-vous en comme exemple. Notons que ces squelettes sont aussi utilisés par le générateur de code PHP qui est décrit dans la chapitre de développement de module Dolibarr pour accélérer vos développement.
Les dates et TimeZone
Dolibarr se veut une application mutli-utilisateur et multi-localisation. Il convient donc de stocker les dates dans le bon format. Pour éviter les problèmes de conversion, les règles suivantes doivent être appliquées:
  • Une date en mémoire doit être au format Timestamp GMT.
  • Une date stockée en base de données contient le Timestamp GMT en rapport avec la date soumise dans la requête en heure locale du serveur PHP. Cela ne concerne pas les dates mises à jour automatiquement par la base (champ tms en base).
Ainsi le 1er janvier 1970, 3 heures à Paris (TZ=+1) = 2 heures à Greenwitch (TZ=0) sera stocké en mémoire 7200 et sera soumis à la base de données avec la chaine '19700101030000' (PHP convertit en heure de son TZ et la base déconvertit avec son TZ qui est le même que celui de PHP).
Les méthodes select doivent donc traduire les champs dates lus qui sont au format chaine TZ de la base ('19700101030000') par appel de la méthode db->jdate afin de récupérer une information en mémoire au format Timestamp GMT. Et les méthodes insert doivent lors de la génération de la requête convertir la date mémoire connue en variable, par la méthode db->idate (Voir exemples générés par le squelette).
  • Les dates mises à jour automatiquement par la base (champ tms en base) contiennent le Timestamp GMT au moment où la modification est faite. Les méthodes select récupèrent directement cette donnée en mémoire au format Timestamp GMT.
L'encodage UTF8/ISO
  • En base de donnée, les données sont en UTF8 ou ISO. Cela dépend du pagecode de la base, donc des options à la création de cette base. Dans tous les cas le driver d'accès base Dolibarr (dans /lib/database) s'arrange à la lecture et insertion pour convertir vers et depuis de l'UTF8.
  • Les données en mémoires sont donc stockées en UTF8 (instances d'objets PHP).
  • Les pages web affichées à l'écran sont au format UTF8 (avec les versions < 2.5.1, c'est le vieux paramètre $character_set du fichier conf.php qui définissait le format de sortie).
Les nombres réels, montants et calculs
print 239.2 - 229.3 - 9.9;
Vous n'obtiendrez pas zéro mais un nombre très petit en puissance de 10 négative. Si vous obtenez zéro, vous pourrez trouvez d'autres exemples qui ne fonctionnent pas. Le problème des float est général, une variable résultante de calcul de nombre réels doit SYSTEMATIQUEMENT être nettoyée par la fonction price2num avec le 2eme paramètre renseigné à: 'MU', 'MT' ou 'MS' selon le besoin (voir doc fonction).
Création de tables
Ne pas créer de table à l'utilisation, c'est-à-dire à la première utilisation du module. Si vous créez un module qui utilise des tables qui ne sont pas intégrées en standard dans le code de Dolibarr, veillez à suivre le didacticiel Créer un module qui explique comment joindre des tables qui se créent à l'activation du module et non à son utilisation (voir plus haut).
Logs
Ajouter des traces dans votre code avec la fonction dolibarr_syslog($yourmessage, LOG_INFO|LOG_DEBUG|LOG_WARNING|LOG_ERR);
Répertoires de travail
Si vous avez besoin de créer un répertoire de travail, dans votre code, faites référence à ce répertoire par DOL_DATA_ROOT.'/monmodule'. Le répertoire peut être créé dans votre code à l'exécution par le code suivant:
if (! is_dir($mymoduledir)) create_exdir($mymoduledir);
Patterns of code organization
Martin Fowler has identified 3 way to organize:
  • The Domain Model
  • The Table Module
-> As shown in code skeletons (see previous chapter), Dolibarr use concept of Table Module.
  • Le Table And Row Data Gateway
C'est le plus simple. On crée une table par classe et chaque classe est un pont avec la table correspondante, voir une classe par ligne de table. Une instance de classe étant alors un enregistrement de la table. La classe ne contient que du code d'accès aux lignes ou colonnes de tables.
  • Le Active Record
Identique au précédent, mais on se permet d'ajouter quelques fonctions métiers sur la classe, à conditions que ces fonctions soient propres à la table ou à l'enregistrement.
Exemple: C'est le mode choisi pour les développements Dolibarr et de nombreuses autres applications PHP qui ont leur propre framework et pratiques de développements.
  • Le Data Mapper
Les classes représentent les entités du problème et non les données. Il faut donc doubler, tripler... ces classes avec des classes Mapper pour accéder aux données. Plus "puriste" sur le papier car plus proche du métier, ce mode a aussi l'inconvénient d'être plus complexe sur le plan pratique. Exemple: C'est le choix si on utilise le Framework d'ORM Propel (http://propel.phpdb.org/trac/). On le trouve donc sur des applications plus lourdes basées sur cet ORM entre autres.
