Table llx facture fourn
Revision as of 07:56, 30 May 2011 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
  Contains invoices sent by providers. A provider invoice can be linked to a provider order (Table llx_commande_fournisseur) by the Table llx_element_element.
  Cette table contient la liste des factures émises par les fournisseurs. Une facture fournisseur peut être liée à une commande fournisseur (Table llx_commande_fournisseur) au travers de la Table llx_element_element
  Contiene las facturas emitidas por los proveedores. Una factura de proveedor puede estar enlazada con un pedido a proveedor (Table llx_commande_fournisseur) a traves de la Table llx_element_element.
Structure
Table
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
facnumber varchar(50) NO UNI invoice number
entity int(11) NO 1 See page Field Multi company id. (llx_entity->rowid)
ref_ext varchar(30) NO See page Field ref_ext.
type smallint(6) NO 0 type of invoice (0=Standard invoice, 1=Replacement invoice, 2=Credit note invoice). For the moment only 0 is supported.
fk_soc int(11) NO UNI ID society (llx_societe->rowid)
datec datetime YES NULL creation date
datef date YES NULL date of invoice
tms timestamp NO CURRENT_TIMESTAMP last update date
libelle varchar(255) YES NULL label
paye smallint(6) NO 0 Is te invoice payed (1=yes, 0=otherwise)?
amount double(16,8) NO 0.00000000 amount
remise double(16,8) YES 0.00000000 discount
tva double(16,8) YES 0.00000000 VAT
total double(16,8) YES 0.00000000 total amount
total_ht double(16,8) YES 0.00000000 total amount excluding VAT
total_tva double(16,8) YES 0.00000000 total amount of VAT
total_ttc double(16,8) YES 0.00000000 total amount with VAT
fk_statut smallint(6) NO 0 Status of invoice (0=draft, 1=unpayed, 2=payed, 3=abandoned)
fk_user_author int(11) YES MUL NULL ID of user author of invoice (llx_user->rowid)
fk_user_valid int(11) YES MUL NULL ID of user validator of invoice (llx_user->rowid)
fk_projet int(11) YES MUL NULL ID of related proyect (llx_projet->rowid)
fk_cond_reglement int(11) NO 1 Id of payment condition (llx_cond_reglement->rowid)
date_lim_reglement date YES MUL NULL date limit for payment
note text YES NULL comentary
note_public text YES NULL public comentary
import_key varchar(14) YES NULL import key
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_facture_fourn_ref UNIQUE facnumber,fk_soc,entity
idx_facture_fourn_date_lim_reglement MULTIPLE date_lim_reglement
idx_facture_fourn_fk_soc MULTIPLE fk_soc
idx_facture_fourn_fk_user_author MULTIPLE fk_user_author
idx_facture_fourn_fk_user_valid MULTIPLE fk_user_valid
idx_facture_fourn_fk_projet MULTIPLE fk_projet
Notes
  Attention, if the status is 1 (unpayed) but the field "paye" is also 1 (payed), which should never happen under normal use, the invoice is specified payed.
  Attention, si le statut est à 1 (impayée) mais le champ "paye" est à 1 également (payée), ce qui ne devrait jamais arriver dans des conditions normales d'utilisation, la facture est indiquée comme payée.
  Atención, si el statut está a 1 (impagada) pero el campo "paye" está a 1 también (pagada), cosa que nunca pasa en condiciones normales de uso, la factura se indicará como pagada.
