Module Third Parties
Third Parties | |
Numéro/ID du module | 1 |
Doc développeur du module | Module Third Parties (developer) |
The "Third Parties" module allows to manage entities customers, prospects and / or suppliers (called Tiers). This module is a pre-requisite for many other modules that are based on these concepts (invoices, orders, contracts, proposals, etc. ...).
A corporation is a business entity: customer, prospect or supplier (Example: An LLC, a trade association, an individual). The contact in turn represents an individual or a generic contact to an individual (Example: CEO of the LLC or worker, dealer principal of Trade, president or treasurer of the association).
Dolibarr operates the same way the third and businesses. Also, for individuals, we will seize usually a "Contact " which contains the same features as the object "Company".
Description of setup of third party module is available on page Module Third Parties setup.
Create a new third party
Go into module Customer - New customer, Prospect - New prospect or Supplier - New supplier. Input all information (fill only mandatory fields if you want).
Once third party is created, you can add some Notes, and add linked files using corresponding tabs.
Modify a third party
Go into menu third party, click on name of third party to modify.
Click on button "Edit" (right botton).
Type all changes.
Click on button "Save".
Delete a third party
Go on third party card and click on button "Delete". Only a third party that has no linked objects (invoices, contracts, orders, etc) can be deleted.
Create a contact
Modifier un contact
Supprimer un contact
Life cycle / Business rules
A third party has only one state. It exists or not. A deleted third party does not change its status, but disappears completely from Dolibarr.
You can create 1 or more physical contact or addresses into a Third party (they will be then used as contacts to send emails for commercial proposals, customer orders, customer invoices, etc...).
Examples of use cases
UCTP01: | |
Situation | I have a new customer, prospect, supplier. |
Actions | Go on menu Third party -> New third party -> Input all data and click on Create. |
