Module Pibarcode
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2011-03-30
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
From the application
Manually
unzip modulefile.zip
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
Development of this module is not included inside standard CVS repository of Dolibarr but into the complementary modules area. So source code is hosted into following CVS repository:
  • CVS Repository: :ext:savannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
  • CVS Module: dolibarrmod
To have a view on changes done on this repository, see page http://www.nltechno.com/stats/dolibarr/cvschangelogbuilder_dolibarrmod.html
