Module BitTorrent
| Module name | |
| Editor / Editeur | NLTechno (www.nltechno.com) - http://www.dolistore.com/ |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2011-03-30 |
| Note / Nota |
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
