Module NumberingPack
Revision as of 13:37, 22 February 2011 by Eldy (talk | contribs) (→‎Informations)
Module name
Dolibarr min version: 2.9.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2011-02-22
Ce pack add more numbering profiles to choose as numbering rules.
From the application
Manually
unzip modulefile.zip
New numbering rules are automatically visibles in modules setup screens.
Development of this module is not included inside standard CVS repository of Dolibarr but into the complementary modules area. So source code is hosted into following CVS repository:
  • CVS Repository: :ext:savannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
  • CVS Module: dolibarrmod
To have a view on changes done on this repository, see page http://www.nltechno.com/stats/dolibarr/cvschangelogbuilder_dolibarrmod.html
