Module Belgium EN
Revision as of 13:16, 22 February 2011 by Eldy (talk | contribs) (→‎Repository CVS)
Module name
Editor / Editeur Laurent Léonard - http://www.open-minds.org
Dolibarr min version: 2.6    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2011-02-22
It allows you to generate and publish InterVAT documents.
Not yet available.
Go into new menu entry "Belgium" to find all new features.
Development of this module is not included inside standard CVS repository of Dolibarr but into the private complementary modules area DoliForge. So source code is hosted into following source repository:
