Module Interventions (developer)
Interventions | |
Numero/ID of module | 70 |
User doc. of module | Module Interventions |
Developer doc. of module | This page |
Feature
This module allows you to manage interventions. You can define some interventions cards that contains one or several intervention lines defined by a comment, a date and a duration. It's goal is principally to follow such activities. In a future version, you should be able to transform interventions cards into invoices.
Entity Intervention
The PHP class to use to manipulate such object is file htdocs/fichinter/class/fichinter.class.php.
Entity Intervention line
The PHP class to use to manipulate such object is file htdocs/fichinter/fichinter.class.php.
Permissions
- ->ficheinter->lire
- ->ficheinter->creer
- ->ficheinter->supprimer
- ->ficheinter->export
