Module Exports En
Exports
Numero/ID of module 240
To export Dolibarr data, there is several solutions described here. This page describe solution using the export module. Solutions to make mass imports are described in the page Mass imports.
  1. Go on menu Tools - Export and choose a predefined dataset.
  2. Then choose fields you wan in your output files, and in which order.
  3. Once data are selected, you can choose the format of the output file build by clicking on the "Build" button.
  4. After few seconds, a file is available for download.
Possible formats are CSV and TSV (Text files) or XLS (Native Excel files)
Outils.png Develop your own export script
If there is no predefined dataset that match your need and have program knowledge, you can also develop your own script. Any language can be used if this language can read a database. You just have to read the table of the entity you want to export and build a file, with format of your choice, from any fields available in table. So the only thing to know is which table contains data you want to export. To help you, page Table SQL presents you the list of all Dolibarr tables.
Note that versions after 2.6 allow "admin" users to see the SQL code used to build export requests when using the module.
