Business Objects
Revision as of 15:22, 3 September 2010 by Eldy (talk | contribs) (Created page with "= Using Business objects = It is possible to use business objects Dolibarr (xxx.class.php files). Each of these files has provided a class of methods for: * recovery of an entity...")
  • recovery of an entity (the fetch method)
  • insertion into database of an entity (the create method or insert)
  • updating an entity (the update method)
  • deletion of an entity (the delete method) if applicable to the object
  • various other methods specific to the entity manipulated.
This technique is better than first one.
Advantages: It offers the advantage of passing through layers of data validation business. The interface code should normally not be rewritten when upgrading version Dolibarr.
Disadvantages: It is usable in PHP only. Your code must be stored on same server than Dolibarr files.
Example for a third party
Here is an example for the creation of a third party (eg customer company):
If we make a new script or an external script, we must add at the beginning, before making anything else:
include('/pathofdolibarrhtdocs/master.inc.php');
This will initialize Dolibarr environment objects ($conf, $db, $lang and $user). If we want that actions (create, update) are tagged with a particular user as the create/update user, we must do after the include of master.inc.php and before calling any create or update method
$user->fetch(0,'loginuser');
Now we can make our business code.
// We declare the class we want to use
include_once('/pathofdolibarrhtdocs/societe.class.php');
// We create an instance of object to manipulate
$mycompany = new Societe($db);
// We set properties on object
$mycompany->nom='Big Brother';
$mycompany->client=1;
// If we want that creation is tagged as done by a particular user 'loginuser',
// you must uncomment this line to load all characteristics of this user.
// If we keep the comment, Dolibarr will use null if fields that should store the create or update user.
// $user->fetch('loginuser');
// On call method to create
$id=$mycompany->create($user);
// This is to read/load an already created object
$mycompany->fetch($id);
// To update object
$mycompany->update($user);
Other examples
You may find other example for manipulating Dolibarr objects (Create, Read, Update, Delete) into directory dev/samples of Dolibarr cvs snapshot.
