Module PHPSysinfo
Module name | |
Editor / Editeur | NLTechno - http://www.nltechno.com/ |
Prerequisites / Prérequis |
Dolibarr min version: 2.9.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2010-08-10 |
Note / Nota |
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
From the application
Manually
unzip modulefile.zip
Click on menu entry "PHPSysinfo". System information will be shown on main page.
Repository CVS
