Module PHPSysinfo
Revision as of 16:06, 10 August 2010 by Eldy (talk | contribs) (Created page with 'Category:Complementary modules Category:PHPSysinfo {{TemplateDocDevEn}} {{TemplateDocUser}} = Informations = {{TemplateModuleInfo |editor=NLTechno |web=http://www.nltechn…')
Module name
Editor / Editeur NLTechno - http://www.nltechno.com/
Dolibarr min version: 2.9.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2010-08-10
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
From the application
Manually
unzip modulefile.zip
Click on menu entry "PHPSysinfo". System information will be shown on main page.
Repository CVS
