Prerequisites
Revision as of 09:14, 29 July 2010 by Eldy (talk | contribs) (→‎Database)
Dolibarr was build to work on following components :
OS
  • Every OS are supported.
For example: Linux, BSD, Windows, MacOS, Aix, ...
Database
  • Mysql 4.1 or +
If using option mode=STRICT returns some warnings or error, please report them to us.
  • PostgresSql 8.1.4 or +
  • MSSql (experimental support not working yet)
PHP
  • Version 4.3.10 or more (need support of the "%0.2F" of the sprintf PHP function to make PDF generation working)
  • Support of user sessions must be enabled (it is the default value in all PHP)
  • Works whatever is the parameter register_globals
  • Works whatever is the parameter magick_quotes
  • Works whatever is the parameter safe_mode
  • PHP configuration must allow use of a max of 16Mb of memory (24Mb required if using Windows).
