Module Imports
Imports
Numero/ID of module 250
To import data into Dolibarr, there is several solutions described here. This page describe solution using the import module. Other solutions to make mass imports are described in the page Mass imports.
Examples of use cases
UCMI01:
Situation I have an excel file with 3000 products. I want to import them into Dolibarr.
Actions Go into menu Tools -> Import -> New import
UCMI02:
Situation I have an text file with 1000 prospects. I want to import them into Dolibarr.
