Script build withdrawal file.php
Feature/Fonction/Funcionalidad
Syntax/Syntaxe/Sintaxis
php build withdrawal file.php  simu|real
  • With value "simu", nothing is done, only informations are shown on output.
  • With value "real", payments are inserted into database and the withdrawal file is built on disk.
Localisation/Localización
  • scripts/withdrawals/build_withdrawal_file.php
Tables used/Tables utilisées/Tablas utilizadas
